dietzp
Mar 28, 2022Aspirant
RBK 853
Hello, I am not really happy with the wifi speed. even so standing nearby the orb router the max I can get is around 750mbits. I am running orbi in AP mode. When I locked into the orbiter router an...
Mar 28, 2022Guru - Experienced User
That would be around what you should be seeing with most 2x2 MIMO supporting devices. What I get with my iPhone 12 Max. 4x4 MIMO supporting devices will see near or over 900Mpbs depending.
dietzp
Hi,
thanks for your reply.
I am actually using a iPhone 12 Pro Max and I new MacBook Pro - so both are capable of 4x4.
any idea about the missing enable ax mode checkbox ?
best
peter
- FURRYe38Mar 28, 2022Guru - Experienced User
I don't think the 12 is 4x4 supporting...only 2x2
What connection rates are you seeing these devices connected at the RBR?
- plemansMar 28, 2022Guru - Experienced User
dietzp wrote:
Hi,
I am actually using a iPhone 12 Pro Max and I new MacBook Pro - so both are capable of 4x4.----no they're not. They're both 2x2 and 80hz wide spectrums. This is apple's guide for the macbook pro. I didn't look up the iphone but its only a 2x2 antenna device as well.
https://support.apple.com/guide/deployment/macbook-pro-wi-fi-specification-details-dep2ac3e3b51/web
Your max link rate is going to be 1200mbps. and thats link rate. throughput tends to be 55-65% of link rate. (apple tends to be a bit higher in the effiency area than others so more towards the higher end.
Unless you have a different wireless card in there? If so, what wireless card do you have?
best
peter
