Moocher
Jun 25, 2022Aspirant
RBK352 but want to add a 3rd satellite but it won't sync ???
Ok... I've had my Orbi RBK352 for 18 months without any issues. We have just moved to a new larger house & want to add an extra satellite to my system but I can't get it to sync. It's only a...
Moocher
I fully understand that not being able to log-in has nothing to do with adding another satellite but how in hell can I add another satellite when the system won't let me log-in ???
It can only be 1 of 3 passwords...
1) The default password
2) The password on the router
OR
3) The password I use to log-in to my account
BUT unfortunately it won't let me log-in with any of these answers...
I have even gone to the orbilogin.net... put in the serial number, it then asks my secret questions. I put in the answers & even that tells me I'm wrong... One messed up system when it's not working properly ... Grrrrrrrrrr
CrimpOn
Jun 25, 2022Guru - Experienced User
Netgear has a Knowledge base article showing how to add a satellite using only the WPS sync buttons on the back of the cases.
https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
Not being able to log into the Orbi router web administration would drive me bonkers. So much so, that I would (and have) done a complete configuration all over again in order to gain access.
When the router is Factory Reset, it erases all user configuration and sets the web login credentials to "admin" and "password".
I discovered early on that in my haste to get finished, I was not deliberate enough with those password reset questions. My experience was that I had to deliberately 'pull down' the list of prompts and select one.
- MoocherJul 08, 2022Aspirant
Just an update a few weeks...
I finally bit the bullet & did a full factory reset. I signed my mesh system up as a complete new setup.
All is now working... BUT I still have a problem, when trying to sign in on the app again...
It keeps coming up with log-in details incorrect... Grrrrrrrrrr
It tells you - Username is "admin"
Password (by default) is "password"
type that in & "Log-in details are in correct"
At least I have all 3 satellites connected now. But I can't get into the app to change anything.
I'm very happy with the system running correctly but it's **bleep**ting me I can't sign in to make changes as required.
- CrimpOnJul 08, 2022Guru - Experienced User
Yes, the app is frustrating when it auto-fills (is that a word?) "admin".
The Orbi app uses the Netgear account login, not the router web credentials. i.e. the same login used to access the community forum.
