Tehflak
Mar 09, 2023Follower
RBK352 less than 10mbps download and upload speed
Hey there, ISPs quoted download speed is 881 mbps and upload is 497 mbps, and on average I'm getting about 3-6mbps on both wifi and lan. Have reset the modem, still did not fix. A bit lost...
Mar 09, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
How are you speed testing? Wired or wireless? Wired is preferred.
What devices do you all have connected?
