satelly
Jan 17, 2022Aspirant
RBK352 OpenVPN
Just recently set up an Orbic RBK352 (AX1800) with 1 router and 1 satellite. Everything connected smoothly including setting up the OpenVPN. However, have seen found that setting up the OpenVPN autom...
- Jan 17, 2022
If it were not so frustrating, this could be fun!
I brought up the WAN Setup page on my old Orbi, put the cursor on the Respond to Ping line, right clicked to "Inspect Element"
I then highlightedd the word 'disabled' and changed it to 'enabled' (see above). That changed the check box to solid instead of grey and I was able to check or uncheck it. I did not click on "Apply" (would be suicide to nertz my Orbi right now)
Maybe you could see if your Orbi has a similar web page?
CrimpOn
Jan 17, 2022Guru - Experienced User
OpenVPN is enabled on my RBR50, and the "Respond to Ping on.." box is unchecked (and greyed out).
On your RBR350, the box is checked and greyed out?
