satelly
Jan 17, 2022Aspirant
RBK352 OpenVPN
Just recently set up an Orbic RBK352 (AX1800) with 1 router and 1 satellite. Everything connected smoothly including setting up the OpenVPN. However, have seen found that setting up the OpenVPN autom...
- Jan 17, 2022
If it were not so frustrating, this could be fun!
I brought up the WAN Setup page on my old Orbi, put the cursor on the Respond to Ping line, right clicked to "Inspect Element"
I then highlightedd the word 'disabled' and changed it to 'enabled' (see above). That changed the check box to solid instead of grey and I was able to check or uncheck it. I did not click on "Apply" (would be suicide to nertz my Orbi right now)
Maybe you could see if your Orbi has a similar web page?
satelly
Thanks CrimpOn. That's correct. The box is checked and dimmed out. I read the same thing on a number of other threads eg. https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Respond-to-ping-enabled-when-using-vpn-on-R7000/td-p/1706699
CrimpOn
Jan 17, 2022Guru - Experienced User
I have come to accept that Netgear changes options from one version of Orbi to the next, often without any obvious benefit, and certainly without any explanation. This one seems just stupid. Why draw attention to the public IP by responding to pings?
It might be interesting to see if disabling OpenVPN restores the ability to uncheck this box. i.e.
- Go into VPN and "un"enable VPN.
- Restart the Orbi.
- Go into the WLAN options panel and see if the Respond to Ping option can be modified.
- (if so) uncheck it.
- Return to VPN and enable it.
- satellyJan 17, 2022Aspirant
Once you un"enable" VPN, the Respond to Ping option can modified and in fact automatically turns off. The problem is that as soon as you "enable" VPN, it automatically turns on and gray out so you cant modify it.
Previously other people have posted about changing the option via Telnet, however I cant seem to access Telnet on my RBK352.
- CrimpOnJan 17, 2022Guru - Experienced User
Thanks for doing the experiment. s**t.
Would this Orbi system be under 90 days old? I would love to hear what Netgear support says about this.
It is true that the original Orbi had an option to enable telnet until firmware V2.7.3.22 removed it. The AX models have never had a telnet option. There is a Python script that will enable telnet on the original Orbi even with the latest firmware. No one has mentioned getting the script to work with any of the AX models.
Really sophisticated users have discovered that it is possible to 'hack' the Orbi web interface by manipulating the web page. They open the page with Chrome or Edge, right click to "view page source", then click on the line they want to change and "inspect element". It might be possible to change that box from whatever mode it is in to an editable mode.
In the broader scheme of things, responding to ping is not the worst thing in the world.
