PawelZawadzkiPL
Aug 26, 2021Aspirant
RBK352 satellite synch issue.
 Dear Community,  I have encountered installing new Orbi RBK352. For some reasons I cannot synchronize satellite once it's relocated into seperate floor. What's very strange is:  1) any personal devic...
- Aug 31, 2021
What is the distance between the router and 📡 satellite(s)?
Try swapping RBS locations with the other RBS to see if problem follows...
Aug 27, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Does the RBS sync when near the RBR?
- PawelZawadzkiPLAug 31, 2021Aspirant
Good Morning
thank you for picking this this topic UP and please see me responces blow :
1) What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too :
It's Polish Orange Funbox 3.0 (FTTH). Circuit based optic converted into eth copper interface (that converter is also provider eqipment ) and then connected into Funbox.
2) What is the size of your home? Sq Ft? :
a) The ground floor is about 65 m2 (+ garage)
b) First floor: 100 m2 (4 rooms + 2 bathrooms and hall).
c) 2nd floor (where I'm expirecing synch issues) 30 m2
What is the distance between the router and 📡 satellite(s)? - currently it's around
- FURRYe38Aug 31, 2021Guru - Experienced User
Hello
current distance (both RBR abd RBS are on the same floor) is approx 8-9 meters. Admin panel shows singal is on poor but sufficent level.
3 walls between. Prefered location where I'd like to place RBS is 2nd floor. Where distance is aprpox 5-6 meters between RBR and RBS.
Again what makes me truly thinking and confused is how's possible that simple IPhone X can get signal from RBR where RBS cannot being in the same place. Same location, same conditions etc.
