P92s
Mar 29, 2021Guide
RBK353 daisy chain setup
Hi there, I'm in the process of changing the configuration of my home wireless to an L shaped form along a corridor with walls on the sides where 2 room are located Wifi should reach the two rooms . ...
Mar 29, 2021Guru - Experienced User
With the new AX systems, its automatic.
I would recommend though, if you plan on daisy chaining, the tribands are a better option than the dual band systems. The dedicated backhauls allow lower latency and higher speeds. (unless you're hardwiring in the satellites, then it doesn't matter)
If the tribands aren't an option, I'd try to centrally locate the router to prevent daisy chaining.
Not saying you can't daisy chain with it but the end of the chain ends up with much lower speeds and higher latency.
P92s
Mar 29, 2021Guide
plemans wrote:With the new AX systems, its automatic.
Thank you for your answer.
So that's why there is no mention in the user manual; may be a few words about it would help ......
Unofrtunately I can't hardwire, ducts are fully loaded. The system I'm planning is with RBK352 that I understand is a triband so I should not loose too much speed and latency. I suppose I might loose some as the connection and backhauls are wi fi, not wired. Distance is about 30 feet for RBR to RBS1 with two light brick walls in between and 15 feet for RBS1 to RBS2 one light brick wall.
Any idea of the potential loss?
- plemansMar 29, 2021Guru - Experienced User
- P92sMar 29, 2021Guide
Oh, Oh Thank you so much !! I did not noticed the difference until you pointed out. Amaz... was taking me there. So I'd be better off with a RBK23 system then. I will give a look at this although here they are selling the RBK23 with one satellite, another single satellite is very expensive.
- plemansMar 29, 2021Guru - Experienced UserThere is a rbk43 renewed on Amazon for pretty inexpensive
