Nakki
Mar 05, 2022Aspirant
RBK353 Internet Connection
Hi, I installed an RBK 353 orbi wifi6 at my parents yesterday. I am left with the strangest wifi problem i ahve ever encountered. The Orbi interface shows Internet not connected, although the PC ...
Nakki
Mar 06, 2022Aspirant
After full resets of the Spark Modem, the Orbi and establishing the wifi and Orbi set up, it fallay seems to be working as it should with internet access across all devices. So, so far so good. It did however reassign the Orbi to an IP address of 10.0.0.1, so i wonder whether there was a clash between the Spark Modem and Orbi's desired IP? firmware now 4.4.0.10.
Mar 06, 2022Guru - Experienced User
Yes, If Orbi is setting a 10.something DHCP LAN IP address pool, this means the ISP modem is using 192.168.1.1 which NG defaults too, Orbi avoids this when detected and changes to someting else.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
- NakkiMar 07, 2022Aspirant
Hi FURRYe38
Thanks for that. Ok, the clash I anticipated, and whilst I knew of the concept of undesirable double NAT, I had fogotten until your post - although once you mention it I now recall disabling my home modem for the same reason some years ago. Thanks for that.
I'll work through the options.. the ISP are not great on support and i am trying to support remotely from ourside NZ so .. we'll see how it goes. I will visit the Modem first and see if the settings are intuitive, if not then the ISP etc and work down the list. Thanks again, I'll drop back if I can't get anything to work. I guess if all else fails then a replacement router that can be confiured easier is the last resort.
- FURRYe38Mar 07, 2022Guru - Experienced User
đ
