BlackForestGuy
Feb 02, 2021Aspirant
RBK353 satellite alternates between solide blue and flashing white
Hi there! I have just gotten a Orbi RBK353, and got it up an running. The base unit is in my living room, one satellite is on the 1st floor, and one satellite is on the 2nd floor. Now, the ...
Feb 02, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- BlackForestGuyFeb 02, 2021Aspirant
FURRYe38 wrote:What Firmware version is currently loaded?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Hi!
FW on the NG router is 4.3.4.7_1.9.53 and on the satellite it's 4.3.4.7.
The modem from my provider (Vodafone) is labelled Arris Touchstone TG3442DE.
I'd estimate the distance (beeline) between the router and the 1st floor RBS is about 12-15 feet, and the distance between the 1st floor RBS and the 2nd floor RBS is around 15 ft. Of course they're all separated by solid concrete walls.
Thanks!
- FURRYe38Feb 02, 2021Guru - Experienced User
Concrete and steel will impact wifi signal and coverage. Not sure if the 3 series system will be good enough to work thru concrete.
Also your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- BlackForestGuyFeb 02, 2021Aspirant
FURRYe38 wrote:Concrete and steel will impact wifi signal and coverage. Not sure if the 3 series system will be good enough to work thru concrete.
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopThanks for this.
I had Wifi disabled already as I have run an Amplifi HD system before.
I asked Vodafone to set the modem to bridge mode, but they said it will take a week for the changes to take effect...? :smileyfrustrated:
For now I've set the Orbi to AP mode instead of router.
