d2iguy
Jan 11, 2020Aspirant
RBK53 Guest Network No Internet and missing checkboxes
Fellow Gearheads, I'd like to see if anyone has run into this issue. I just replaced my RBR50 and RBS50 system with the RBK53. In place are the RBR850 and the RBS850. Upon deployment, I upgraded both...
Anonymous
Apr 06, 2020
dcraig wrote:I am having the same issue, but I am now using the RBR850 in Router mode. I had the exact same problem when I had the RBR850 configured in AP mode. However, the Guest network appears to work fine when I'm conncted to the RBR850. But when connected to one of the Satellites, the Guest network appears, but shows "No Internet Connection."
I believe this problem is a result of having a switch in between the Router and Satellites (using wired backhaul), but have not confirmed...
I have the same issue, and I have no switch between the RBR and RBS just a cat5e direct to each other.
I have asked for access to beta-firmware, will confirm if this fixes it.
Apr 06, 2020Guru - Experienced User
Let us know how it goes for you.
