d2iguy
Jan 11, 2020Aspirant
RBK53 Guest Network No Internet and missing checkboxes
Fellow Gearheads, I'd like to see if anyone has run into this issue. I just replaced my RBR50 and RBS50 system with the RBK53. In place are the RBR850 and the RBS850. Upon deployment, I upgraded both...
Aug 22, 2020Guru - Experienced User
Yes, I checked the RBS web page and saw my devices connected at the RBS while GN was enabled and they were on the Guest network. This was in router mode.
philoouu
Aug 22, 2020Luminary
you wrote you checked the RBS web page.
I dot not have a detailted list when I connect with a browser to the RBS web page.
I need to go to the main unit RBR to get a list to check who is connected to who.
What do you see exactly on the RBS web page ? I see only the main network, I never see the guest network.
On the RBR web page I see everything.
Thanks
