Isahar
Jun 30, 2024Aspirant
RBK652 and RBR50
I have been using the RBR50 mesh system for 7 years, and it has been amazing. Now, I have purchased a new RBK652 system, which includes one satellite. Is there a way to integrate the RBR50 sate...
Jun 30, 2024Guru - Experienced User
No. They don't integrate.
You can use it separate if you'd like. Just make sure to use a separate ssid and have the wifi on different channels to prevent interference. Put the 2nd system in access point mode to prevent a double nat
