Bobh1072
Jan 21, 2024Follower
RBK653
If installing a new Netgear Mesh WiFi system (AX3000 with RBK653 Router), with 2 satellites, is a physical connection required between service providers internet router ( Cat 5 Cable) and the netgear...
CrimpOn
Jan 21, 2024Guru - Experienced User
The router can be connected Only with an Ethernet connection.
- CrimpOnJan 21, 2024Guru - Experienced User
Should point out that the ISP modem and the RBR650 must detect the connection to be Ethernet.
It could be a MoCA link, a Powerline link, or even a microwave link. As long as the router "sees" an Ethernet connection, it will be happy.
For the vast majority of customers, a physical Ethernet cable between ISP modem and Orbi router is the obvious connection.
