Bobh1072
Jan 21, 2024Follower
RBK653
If installing a new Netgear Mesh WiFi system (AX3000 with RBK653 Router), with 2 satellites, is a physical connection required between service providers internet router ( Cat 5 Cable) and the netgear...
CrimpOn
Jan 21, 2024Guru - Experienced User
The router can be connected Only with an Ethernet connection.
CrimpOn
Should point out that the ISP modem and the RBR650 must detect the connection to be Ethernet.
It could be a MoCA link, a Powerline link, or even a microwave link. As long as the router "sees" an Ethernet connection, it will be happy.
For the vast majority of customers, a physical Ethernet cable between ISP modem and Orbi router is the obvious connection.
