gman88
Apr 21, 2021Tutor
RBK735S 3 unit mesh drops WiFi daily for 2-3 minutes - Anyone Experiencing This?
(reposting to correct forum) My 3 week old RBK735S 3 unit mesh drops WiFi daily for 2-3 minutes. Is anyone else working from home and noticing this random interruption daily? For me, I'm on video c...
- Apr 28, 2021
All,
Thanks for your suggestions. As a follow-up to my note of 2021-04-22 04:22 PM, I made several changes which seem to have had some positive effects.
Per my other note, per suggestions on Reddit, I:
- Turned off Traffic Meter,
- Disconnected my one hard wired device from a Satellite
- Continued to add devices to Advanced -> Lan Setup -> "Address Reservations"
- Changed my NTP server. NTP was showing Dec, 2020
- I renewed my DHCP lease for the Router, to a time of day just before going to bed, with a 7 day renewal duration.
- I have also been running a ping command non-stop to 8.8.8.8 and logging the output (2 pings every 5 seconds).
That combination of changes has provided some stability over the past week. I suspect the root cause may have been with the Traffic Meter (#1) (many on Reddit seem to think so), but also (#4 and #5) might be better hiding the issue as it may be happening when I sleep now. I'm not totally convinced of this because while some ping drops occur, I no longer see 2-3 minutes of total network loss between the RBR and the Modem. There have also been no patches auto downloaded this week, which could also be the root cause for these interruptions.
Also worth mentioning, that on item #4, I was not able to provide ntp IP addresses for "Set your preferred NTP server". Rather I had to specify a A Record, which took me a while to figure out "time.nist.gov" did the trick.
I'll let you know if I have anything further to share.
Apr 22, 2021Guru - Experienced User
Try testing with out any RBS online. Then try test with 1 RBS then 2 RBS. Swap locations with the RBS to see if the problem follows.
Disabling DHCP will cause devices to not get a IP address when they are Dynamic configured for IP addressing.
gman88
Apr 22, 2021Tutor
So I have confirmed in the Logs that after each of these incidents, which are now happening several times per day, there are several DHCP requests and so I suspect this is somehow part of the issue. You can see some of the same devices are retrying several times to get a lease.
[DHCP IP: (10.0.0.15)] to MAC address 78:4F:43:64:5E:E2, Thursday, Apr 22,2021 16:08:46
[DHCP IP: (10.0.0.9)] to MAC address 14:C1:4E:01:BE:34, Thursday, Apr 22,2021 16:08:44
[DHCP IP: (10.0.0.6)] to MAC address F2:8B:92:56:EA:F0, Thursday, Apr 22,2021 16:08:27
[DHCP IP: (10.0.0.6)] to MAC address F2:8B:92:56:EA:F0, Thursday, Apr 22,2021 16:07:33
[DHCP IP: (10.0.0.9)] to MAC address 14:C1:4E:01:BE:34, Thursday, Apr 22,2021 16:06:51
[DHCP IP: (10.0.0.9)] to MAC address 14:C1:4E:01:BE:34, Thursday, Apr 22,2021 16:04:58
[DHCP IP: (10.0.0.9)] to MAC address 14:C1:4E:01:BE:34, Thursday, Apr 22,2021 16:03:13
[DHCP IP: (192.168.2.9)] to MAC address 3A:E0:AF:F8:AB:DB, Thursday, Apr 22,2021 16:02:25
[DHCP IP: (10.0.0.6)] to MAC address F2:8B:92:56:EA:F0, Thursday, Apr 22,2021 16:01:59
[DHCP IP: (192.168.2.6)] to MAC address 7C:2A:31:6A:A5:54, Thursday, Apr 22,2021 16:01:31
[DHCP IP: (10.0.0.14)] to MAC address 7C:2A:31:6A:A5:54, Thursday, Apr 22,2021 15:53:30
[DHCP IP: (10.0.0.17)] to MAC address DC:FB:48:BE:B4:6E, Thursday, Apr 22,2021 15:44:59
[DHCP IP: (10.0.0.19)] to MAC address DC:71:96:83:45:4B, Thursday, Apr 22,2021 15:21:12
[DHCP IP: (192.168.2.3)] to MAC address 48:43:DD:3E:8F:9A, Thursday, Apr 22,2021 15:17:06
[DHCP IP: (10.0.0.19)] to MAC address DC:71:96:83:45:4B, Thursday, Apr 22,2021 15:15:11
[DHCP IP: (192.168.2.8)] to MAC address 9C:5A:44:C5:4B:64, Thursday, Apr 22,2021 14:47:09
[DHCP IP: (192.168.2.7)] to MAC address DC:71:96:83:45:4B, Thursday, Apr 22,2021 14:25:58
[DHCP IP: (192.168.2.7)] to MAC address DC:71:96:83:45:4B, Thursday, Apr 22,2021 14:23:44
[DHCP IP: (10.0.0.17)] to MAC address DC:FB:48:BE:B4:6E, Thursday, Apr 22,2021 13:56:47
[DHCP IP: (10.0.0.14)] to MAC address 7C:2A:31:6A:A5:54, Thursday, Apr 22,2021 13:52:44
[DHCP IP: (10.0.0.17)] to MAC address DC:FB:48:BE:B4:6E, Thursday, Apr 22,2021 13:36:51
[DHCP IP: (10.0.0.17)] to MAC address DC:FB:48:BE:B4:6E, Thursday, Apr 22,2021 13:29:14
[DHCP IP: (192.168.2.2)] to MAC address F8:54:B8:71:97:94, Thursday, Apr 22,2021 13:26:58
[DHCP IP: (10.0.0.14)] to MAC address 7C:2A:31:6A:A5:54, Thursday, Apr 22,2021 12:57:30
[DHCP IP: (192.168.2.3)] to MAC address 48:43:DD:3E:8F:9A, Thursday, Apr 22,2021 12:50:49
[DHCP IP: (10.0.0.14)] to MAC address 7C:2A:31:6A:A5:54, Thursday, Apr 22,2021 12:46:15
On Reddit there were some additional suggestions which I performed ahead of this latest 16:03 outage:
- Disable Traffic Meter
- Disconnect any hardwired devices from ethernet ports
- Reserve IP addresses for both Satellites (attempt to avoid DHCP requests from those devices)
- Reboot Router, then Satellite #1, then Satellite #2
I have to say, I think I've tried everything at this point and will likely return the Mesh, unless someone can help. Netgear support is worthless. Their help was to upgrade the firmware (which I already did).
For $700, you expect this hardware to work out of the box. This is rediculous.
- FURRYe38Apr 22, 2021Guru - Experienced User
Please do not include any MAC addresses in public forums.
I see both 10 and 192 addresses being in the mix. I believe this is due to your modem being in router mode. I would be best to bridge this modem if possible. Is the 10 addresses coming from the RBR or from the ISP Modem? I believe they are coming from the RBR since 10 maybe set on the RBR due to the ISP modem using 192.168.1.1 and the RBR avoids this conflict and sets 10.
Yes you can set IP address reservations for the RBS on the RBR. What I do when mines in router mode.
Would need to check with the RBS turned OFF if the problem persists with the RBR alone and see.
- gman88Apr 23, 2021Tutor
Address Space:
- Modem (LAN Side)
- 192.168.0.1
- Netmask 255.255.255.0
- RBR
- Address on Modem network side: 192.168.0.2
- RBR Main Network:
- 10.0.0.0
- Netmask: 255.255.255.0
- Given this, I don't see any address overlap and thus no compelling reason to mess with my ISP Modem for bridging.
- RBR Guest Network
- 192.168.2.0
- Netmask: unknown but assuming 255.255.255.0. Where in the orbilogin.com can I confirm guest network netmask (it is not on LAN Setup, nor Guest Network pages)?
I enabled address reservations for both RBS yesterday, and the issue occurred regardless. What was different is that neither RBS sent a DHCP request after the incident. So reservations are working, but whatever the root cause, it's still occurring.
I had been hoping the resolution of NTP would address the issue (RBR thought it was Dec, 2020), as whatever magic maintenance is happening with these devices is supposed to occur during the evening or night, where I would not be working (and kids not in remote learning), thus not impacting us. But as of yesterday with corrrected NTP setting it did not help.
- FURRYe38Apr 23, 2021Guru - Experienced User
Did you set a 10.0.0.0 addresss on the RBR or did the RBR do this?
- Modem (LAN Side)
