DolceArdore
Apr 26, 2024Aspirant
RBK750 - Devices lose connectivity when moving from base station to satellites (wired backhaul)
I have an RBR750 with two RBS750, all devices on firmware V7.2.6.31. Each satellite is connected to the base station over gigabit ethernet. Once any wireless device successfully connects to the net...
KevinLiT
Nov 27, 2025NETGEAR Moderator
Hello Garwoofoo ,
Welcome to the NETGEAR Community!
In the future, please create a separate new post for the issue that you are experiencing so that we can analyze the case objectively. Your post mentioned that firmware updates did not fix the issue, this may be due to the security measures used by Apple. To resolve this issue you can try turning off your private IP address on your iOS device.
To turn off the Private IP address please follow the directions listed below:
Open "Settings"
"Wi-Fi"
Select the "i" icon next to your connected network
Toggle off "Private Wi-Fi Address"
Best,
Kevin
NETGEAR Team
- GarwoofooNov 29, 2025Apprentice
Thanks Kevin. I first reported this issue back in 2022, including the fact that your suggestion there doesn't do anything to fix it, so I'm not sure how many times you want people to post the same things.
