dswchui
Jan 08, 2024Follower
RBK750 -> RBS750 Speed
Hello, I have a RBS750 connected to a RBK750 on a 5GHz backhaul. I tested the speed on the router setup page to be around 980Mbps. I have a 1000Mbps connection so that speed more or less checks out. ...
Jan 08, 2024Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
There maybe some speed degradation between the RBR and RBS due to wireless distances and building materials. Not sure you can do with that.
