som1999
Sep 30, 2020Aspirant
RBK750 Access Control does not block device
I've just installed a new router (RBR750 + RBS750) and turn on the access control with a short list of allowed devices. I tested it by loggin on from a PC that is not on the access list with expecta...
Mstrbig
Oct 01, 2020Master
I tested here and it works fine.
So you turned on Access Control
you unchecked "Allow all new devices to connect "
And you checked "Block all new devices from connecting"
That's how I set mine for testing. After setting, I rebooted the router via the GUI at orbilogin.com > Advanced > Advanced Home
- som1999Oct 01, 2020Aspirant
Thank you for the info. I've also opened the case wtih Netgear and got a response that I don't feel comfortable.
<cut & paste from their reply>
Using the access control feature it is to block devices from connecting to your router’s Internet connection. Blocking devices with access control only blocks them from accessing the Internet. Devices can still access your router’s local network and communicate with your connected devices.....
I tested it and it's true. I used access control more to prevent unknown device to hack into my local device rather than limit internet bandwidth. So this current method doesn't work for me.
