Russjefferies
Jul 27, 2021Aspirant
Rbk750 and rbs750
Guys looking for 2 extra satellites for my orbi setup, are the RBK750 and RBS750 the same thing? also, I have the rbr750 with 2 satellites can I add an extra 2? cheers in advance
Jul 27, 2021Guru - Experienced User
Any RB(K)it mean that there is 1 RBR### router and 1 or more RBS### satellite included in the box set. So yes any RBS750 from a RBK7 series kit will work with a RBR750.
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System 📡
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Russjefferies
Thanks for the swift reply, so I can add 2 extra satellites cool.
the main reason for asking the difference is I was thinking of buy 2 of these, but wasn't 100% they were satellites, it says they are in the description but the K in Rbk threw me
- FURRYe38Jul 27, 2021Guru - Experienced User
Just be aware that the RBR can not operate like a RBS. It only supports router mode or ethernet connected AP mode that would be connected to a host router upstream from it and would not integrate into another Orbi mesh system.
- RussjefferiesJul 27, 2021Aspirant
So best to get rbs for WiFi connection.
basically putting one in a garden room to give it WiFi. I've ran Ethernet from the garden room to my garage, plan on putting a satellite in the garage to connect wirelessly to the orbi router, then connecting the Ethernet to another satellite in the garden room.
Would connect the garage satellite to the orbi router by Ethernet but it would be a nightmare getting it there
I believe that should work. I haven't tried RBS ethernet connected to another RBS.
