aluch's avatar
aluch
Follower
May 26, 2022
rbk750 connection issues
I recently upgraded from the RB50 series to the RBK750 series. Now I have a wifi power switch that randomly loses connection - sometimes they reconnect on their own; however, they require a power reset.  I've tried customer service they had me change the broadcast channels (this had no effect). Nxt they had me do a firmware downgrade (this did help some in that some of the switches now seem to stay connected, also prior once they lost connection they would not reconnect, now about half the time they reconnect).
I have the main route and satellites in the exact same location and before and actuall have a bit stronger signal strength width the 750.  All of the switches are on the 2.4G side and they are all from the same vendor.   Also seem to be connected through the satellite.
Anyone else have this problem or found a fix?
1 Reply
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor, SPC, Traffic Meter.
    Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
