RjDes
Aug 09, 2021Initiate
RBK750 Keeps dropping connection, not connecting to satellites and only router
Guys please I need your help. We have three people working from home and my network keeps dropping. I paid over the top for RBK750 with a router and 2 satellites. it was good initially but now the ne...
Aug 26, 2021Guru - Experienced User
Please make a new post in the main forum and we'll help you out.
Thank you.
duomono wrote:
Hi all
Just bought the Orbi 6 RBK852/850 2 weeks ago … the coverage and speed is good but the Wifi network discounting 2-3 times a day is a huge headache when your home is set up with ‘smart’ but wifi dependent products. I’ve also hosted an online event and got disconnected. When I called netgear, they claimed it’s not their product problem and they can fix it - blaming on my network - at a fee. I told them the product is sold at a price that we should expect decent support. Disappointing experience with Netgear!
I hope we can find some solutions here.
morechoff
Sep 13, 2021Guide
I have the exact same issue with RBK750. Connection to the Internet via Wifi drops for about 5 mins. Does not happen everyday (at least i dont notice it). Very frustrating. This is new setup that I just bought at Costco.
Mike
- FURRYe38Sep 13, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Mike
- morechoffSep 14, 2021Guide
Firmware on the RBK750 router is v4.6.3.16.
I am running on Spectrum using the Netgear CM700 modem. Firmware is Spectrum version. I have no control over the firmware.
House is about 3700 sq feet. I have two satelites. The modem is located in the family room on the 1st floor, one satelite is about 40 feet away on the 1st floor. The 2nd satelite is upstairs.
House is built out of wood and has drywall. No brick.
Issue I have is that the router loses internet connectivity for about 5 mins (maybe a bit less) periodicaly. It does come back. The RBK750 is brand new (a month or so old).
I was able to connect to the ethernet port on the modem using hard wire and internet was working. The issue is the router.
Mike
- FURRYe38Sep 14, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
Mike
