KAMMAX
Jun 08, 2023Follower
RBK750 missing Advanced WLAN Settings
Hello, I changed my Orbi RBK23 to an Orbi RBK753 and it turned out the RBK23 was better! Because of the missing settings for Implicit-Beamforming, MU-Mimo and Fast Roaming And i can tell you ...
- Jun 09, 2023
As mentioned already, those options are all automatic and were never seen or available in the WEB UI when Orbi AX systems first came out. I presume NG won't be making these available in the future as well.
You shouldn't need to make changes with these anyways. Most all devices work with Orbi AX systems these days.
schumaku
Jun 09, 2023Guru - Experienced User
These options are not made available to the user control on Orbi AX. They are enabled by default now (and for a long time).
