KAMMAX
Jun 08, 2023Follower
RBK750 missing Advanced WLAN Settings
Hello, I changed my Orbi RBK23 to an Orbi RBK753 and it turned out the RBK23 was better! Because of the missing settings for Implicit-Beamforming, MU-Mimo and Fast Roaming And i can tell you ...
- Jun 09, 2023
As mentioned already, those options are all automatic and were never seen or available in the WEB UI when Orbi AX systems first came out. I presume NG won't be making these available in the future as well.
You shouldn't need to make changes with these anyways. Most all devices work with Orbi AX systems these days.
Jun 09, 2023Guru - Experienced User
CrimpOn
The RBK753 Product Data Sheet describes these capabilities:
https://www.netgear.com/images/datasheet/orbi/RBK753.pdf
Fast Roaming is not mentioned in the Product Data Sheet, but is also "standard".
It often comes as a surprise when Netgear removes the ability to control features without explanation. There are other examples such as the ability to enable/disable broadcasting the SSID. (Present on the original Orbi. Absent on the AX products.) The original Orbi had an option for devices on the guest network:
This option disappeared with the AX product line.
