Retired_Member
Aug 03, 2022RBK750 no way to disable SSID broadcast. Option was removed from latest firmware update.
RBK750 no way to disable SSID broadcast. After a few days on the phone with several tech-support agents, it was finally determined that this option was removed from the latest firmware. There is ...
Retired_Member
Aug 04, 2022Well they lied to me because I called before I bought the system and they specifically said that it did so I guess is that what I’m expected to see with further tech-support thank you for your reply appreciate it.
I have a issue I have a slow iOS devices such as my iPad and phone anyone know about that
Aug 04, 2022Guru - Experienced User
How are you testing with the devices? Be sure they are connected to the RBR before doing any speed tests. Turn OFF the wifi radio on the devices for 5 seconds then back ON while near the RBR. Then speed test.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What are your current CTS values Under Advanced Tab/Advanced Settings/Wireless Settings
Try enabling SIP ALG on the RBR. Under Advanced Tab/Setup/WAN Setup
- Retired_MemberAug 04, 2022
Thank you I will try all those.
