hambony
Feb 28, 2024Initiate
RBK750 port aggregation with cm2050v
So I now have a CM2050V with a single 2.5gb port on the back, looking to get the fastest speed to my RBK750. I'm not the most savvy, but is it feasible to run an ethernet to a 2.5gb switch from the ...
Feb 28, 2024Guru - Experienced User
Would depend on switch and it's support of handling LAG and such. Other LAN ports are limited by 1Gb so you'd not see anything much over 900Mpbs on the wire. Wireless, could see over 900Mpbs if your devices supported 4x4 MIMO.
I'd just go with keeping it simple, until maybe such time the RBR could be updated to a RBR that had 2.5Gb or higher support like the 850/860 series that have multi gig WAN ports however are still limited by 1Gb LAN ports. Orbi 9 series has both WAN and LAN support with multi gig speeds.
