hambony
Feb 28, 2024Initiate
RBK750 port aggregation with cm2050v
So I now have a CM2050V with a single 2.5gb port on the back, looking to get the fastest speed to my RBK750. I'm not the most savvy, but is it feasible to run an ethernet to a 2.5gb switch from the ...
hambony
Feb 29, 2024Initiate
Thanks for the replies, I might just try it out. This all stems from upgrading my computer that does double duty as a Plex server as well (main computer duties, aside from Plex, is farting around on the internet, lol). It's one of those things where I looked at it and thought "I wonder if...", and that always leads to trouble.
- FURRYe38Feb 29, 2024Guru - Experienced User
I'd save off a back up configuration to file on the RBR for safe keeping. Saves time if a factory reset is needed: 😉
- plemansMar 01, 2024Guru - Experienced User
Before I had the RBK963/RBE973, I was looking at picking up a mini-pc with 4x 2.5gig ports and installing pfsense to it. If I remember correctly, it was around that $250 when I priced it out with modest specs a couple years ago. For some reason, I really wanted to build my own router as the performance is supposed to be fantastic. I was planning on using that for the multigig option and run the wireless router setup I had in access point mode. I didn't go that route but it could be an option. I imagine prices have dropped since I was researching it and it might even work pretty rock solid and give you extra options for performance.
And not sure what you're running on your plex server or how capable you are (technologically) but you might be able to run pfsense in a docker container and add a dual 2.5gig nic card to your plex computer. It could potentially run the router and plex server as one. I've investigated that as well. A 2x 2.5gig wan card can be picked up for around $30-40 on amazon. That might be a cheap option to get mutigig from your cm2050v.
Oh the dangers of DIY
It'd take a little coding/time to setup but something like this user did:
https://joshspicer.com/homelab
And then you'd install the plex server to one of the VM's or in its own docker container.
But again, you'd need a little expertise and willingness to modify.
