Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
huisakuraflower
Aug 03, 2021Initiate
I had the new update for a few days now, and ever since the update, my wifi/internet connection has been unstable. It will go on and off a few times every day. Internet speed is also slower, with youtube choosing 360P even during non-peak hours.
Am I the only one experiencing such a problem? Are there any solutions available?
Dieselrose
Aug 03, 2021Tutor
RBK750, and yeah my internet has gone from 900MBPS TO 6000MBPS when I do a speed test, and my Xbox Series X which I have CAT 6 Ethernet cable running to is now capped at 95MBPS download speed since this update!
Fix this now!
Fix this now!
- FURRYe38Aug 03, 2021Guru - Experienced User
- B_K_CAug 11, 2021Initiate
Fix this now!Same here, after firmware update my internet speed (link aggregation) from 1400mbps to 620mbps - reduced to more than half, this is rediculous!! I'm sooooo regretting doing the firmware update to V4.6.3.7
FIX THIS PLEASE!!!!!!!
CM1100 + (Orbi RBR750 + (2)RBS750)
- FURRYe38Aug 11, 2021Guru - Experienced User
Is this speed result at the RBRs internal speed test app or thru a external speed test app like Ooklas installable speed test app?
- WaliuddinAug 11, 2021Guide
You can downgrade from V4 to V3. Just go to www.support.netgear.com in the box type your model router number > Next page click Downloads > under Firmware and Software Downloads Click (+) Previous Versions > Download the latest V3 update file and then extract it. It will be a .chk file that you need to upload it.
Do the same steps for the satallites as well.
let me know if you need steps uploading the firmware to your router
Version 4 has decreased internet speed to more then HALF
CM1200> RBR750 + (2X) RBS750
