Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
B_K_C
Aug 11, 2021Initiate
Dieselrose wrote:
RBK750, and yeah my internet has gone from 900MBPS TO 6000MBPS when I do a speed test, and my Xbox Series X which I have CAT 6 Ethernet cable running to is now capped at 95MBPS download speed since this update!
Fix this now!
Same here, after firmware update my internet speed (link aggregation) from 1400mbps to 620mbps - reduced to more than half, this is rediculous!! I'm sooooo regretting doing the firmware update to V4.6.3.7
FIX THIS PLEASE!!!!!!!
CM1100 + (Orbi RBR750 + (2)RBS750)
Waliuddin
Aug 11, 2021Guide
You can downgrade from V4 to V3. Just go to www.support.netgear.com in the box type your model router number > Next page click Downloads > under Firmware and Software Downloads Click (+) Previous Versions > Download the latest V3 update file and then extract it. It will be a .chk file that you need to upload it.
Do the same steps for the satallites as well.
let me know if you need steps uploading the firmware to your router
Version 4 has decreased internet speed to more then HALF
CM1200> RBR750 + (2X) RBS750
