Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
Aug 12, 2021Guru - Experienced User
Has the Orbi been factory reset since the FW was updated?
Atllaw
Aug 13, 2021Star
No, I rebooted the modem, but haven’t done a factory reset. Other people were using the network last night so didn’t want to knock everyone off to change channels and ports, both since other people said it didn’t work for them and also since the support’s first conclusion was that plugging it into the wall would fix it (the router is the only thing plugged into the power strip).
For me, I just spent a ton of time setting this thing up and tweaking it so I could get the best performance. To have Netgear just come in and knock it all down with a stupid firmware update that they knew was faulty is frustrating to no end and if I have to reconfigure it, I would rather just start with something else which is either more reliable or cheaper or both.
- FURRYe38Aug 13, 2021Guru - Experienced User
Good Luck then.
