Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
Timothy88
Jul 31, 2021Luminary
Whne using the Orbi speedtest before uprading to latest firmware (4.6.3.7) the results were pretty much in sync with speedtest app or website. It is now about 300 Mbps slower consistently. When I test usign the speedtest app or website I get over 900 Mbps very consistently if I login into the router usign the web interface on the same PC the Orbi speedtest shows only over 600 Mbps. This was not a proble on the previous firmware. AX4200 RBR/RBS 750
scoboo
Aug 21, 2021Guide
Hello,
Did you ever resolve this? We have the EXACT same problem!
I even 'upgraded' from the RBK 750 to the RBK753S. As long as the router had firmware 3.1.18.1, we got accurate speed and the wifi did not drop. But then Netgear removed the option to select whether to auto-upgrade f/w...which means our f/w auto-upgraded to 4.6.3.7!! So now we're back to the exact same problem as you identified in this post.
Any ideas?
The agent I spoke with today at Netgear is escalating this issue to a senior technical lead.
Thanks
Scott
