Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
Waliuddin
Aug 11, 2021Guide
You can downgrade from V4 to V3. Just go to www.support.netgear.com in the box type your model router number > Next page click Downloads > under Firmware and Software Downloads Click (+) Previous Versions > Download the latest V3 update file and then extract it. It will be a .chk file that you need to upload it.
Do the same steps for the satallites as well.
let me know if you need steps uploading the firmware to your router
Version 4 has decreased internet speed to more then HALF
CM1200> RBR750 + (2X) RBS750
scoboo
Aug 21, 2021Guide
I tried this with a tier 2 Netgear technical support agent and we didn't have any success. Have you verified this as a solution?
