Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
scoboo
Aug 22, 2021Guide
I spent two hours today with a senior level tech at Netgear.
She used iStumbler app to identify that there are quite a few networks in the area of our residence that may be causing interference.
She changed the following:
orbilogin.net/start.htm
Advanced tab
Wireless Setup
Under Wireless Settings header:
change 2.4GHz Channel to "11"
change 5GHz Channel to "36"
This change has increased our wireless signal by 30-50%.
That said, Netgear engineers are continuing to monitor our devices in order to debug the issue with firmware V4.6.3.7_2.0.49.
The above setting change is a TEMPORARY solution. Hope it helps!
Aug 22, 2021Guru - Experienced User
If you have lots of wifi neighbors near by, try turning down the power output of the RBR wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
orbilogin.net/start.htmAdvanced tab
Wireless Setup
