Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
Timothy88
Aug 29, 2021Luminary
Yes I have performed several power cycles. This is the third time this has happend since the update. I have not performed a factory reset since the update as from reading the posts in this thread it seemed to have not effect on resolving any of the issues mentioned. I can do a factory reset but I have a lengthy list of reservations that I would need to re-add.
Aug 29, 2021Guru - Experienced User
So you have powered OFF both ISP modem and RBR?
When the RBR seems to loose connection, does the front LED turn ON PINK?
When you factory reset, have a backup configuration to file saved. Saves time if a reset is needed.
Try what this user did:
- Timothy88Aug 29, 2021Luminary
Yes when it loses connected it goes magenta or pink.
What a Joke. I reset defautls and restored fro a backup and it changed half of the names in my reservation list to something orhte than what I had them named and cant' find my armor subscription.
- FURRYe38Aug 29, 2021Guru - Experienced User
You might revert back to v3 if v3 is what had been working for you:
Netgear should be compensating us for all of this wasted time. What a terrible release, the develpoers and QC should be ashamed of themselves for a release this troublesome.
The reversion sounds painful too.
I'm not holding my breath but hopefully the restore fixed the isses.
