Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
Xcelebric
Aug 23, 2021Guide
Here is the latest update from my trying:
1. Downgrade the Firmware to V3.2.10.10 for both Router and the Satellite, which is the very first Firmware version. Using the way I mentioned in previous thread that pressing F12 in the downgrade page and unhide the Yes button.
This Firmware version has Telnet option on Debug page.
2. After that, perform factory reset on both Router and the Satellite.
3. Finish basic configuration, but DO NOT connect to internet yet.
4. Enable Telnet option on both Router and the Satellite in their Debug.html page.
5. Telnet connect to both devices, and ran the following:
nvram set auto_upgrade_enable=0
nvram set ver_check_https_svr1=http.fw.updates1.aaa.com
nvram set ver_check_ftp_svr1=updates1.aaa.com
nvram set ver_check_ftp_svr2=updates1.aaa.com
nvram set ver_check_ftp_svr3=updates1.aaa.com
nvram set lang_check_ftp_svr=updates1.aaa.com
nvram set install_fw_upgrade_latest=0
nvram set ver_check_enable=0
nvram set ver_check_ftp_password=aaa@aaa
nvram set control_cloud_backend_fw_url=https://http.fw.updates1.aaa.com
nvram set promotion_server=updates1.aaa.com
nvram commit
6. Make sure the above run on both devices.
7. Go to Managment page -> Advanced -> Security -> Block Sites :
a. Keyword Block set to "Always"
b. Add the following key words:
http.fw.updates1.netgear.com
c. Click Apply.
8. Perform a Soft reboot from Advanced Home : -> Reboot -> Connect back to the Internet.
9. After that, my firmware update page showing this:
Status:
Router RBR750 RBR750 V3.2.10.10 Service unreachable
Satellite RBS750 Orbi Satellite-1 V3.2.10.10 Service unreachable
10, I will monitor for a day or so to see if this works.
Timothy88
Sep 04, 2021Luminary
I wish Netgear would allow easily downgrading firmware instead of having to stand on your left foot while patting your head and reciting the alphabet backwards on the second Tuesday of the first full moon.
- intergeek14Sep 04, 2021StarThey used to. They just don’t want you getting away from the new service they are trying to sell.
- Timothy88Sep 04, 2021Luminary
Good business model we'll make your system unstable so you buy our additional service but still get no resolution, so now you're even more PO'd
- Timothy88Sep 04, 2021LuminaryHas anyone looked at or have any experience with the ASUS ZenWiFi AX (XT8)?
- raven_auSep 04, 2021Virtuoso
Timothy88 wrote:
Has anyone looked at or have any experience with the ASUS ZenWiFi AX (XT8)?You can find out all you need to know over at Small Net Builder forums.
- FURRYe38Sep 05, 2021Guru - Experienced User
By the looks of it, they seem to have there own issues too. :smileywink:
