Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
Sep 05, 2021Guru - Experienced User
ALL USERS of the 7 series Orbi AX system, please contact NG support by opening a support ticket and contact NG and ask them for the beta that seems to be avialable for the 7 series that seems to be directed to fixed what everyone with a 7 series has been having problems with:
https://www.netgear.com/support/#
For user out of warranty, contact Blanca_O and DarrenM and send them a PM and ask for the beta.
Good Luck.
Theobuck
Sep 06, 2021Apprentice
Netgear support has no idea about a beta version.
- TheobuckSep 06, 2021ApprenticeIf you call Netgear support, be ready to do troubleshooting you don’t want. I factory reset ( I explained it would not help, and it didn’t). Changed my DNS server (it didn’t help). Finally, I got to tier 2. They had me upload a ton of files, so now I wait. But still no beta version FW.
- AggedwNGSep 06, 2021ApprenticeI have a strong suspicion that these issues are tied in to Armor.. Their push for cloud security and this fw limiting the ability to downgrade (or attempting to) is curious in timing. I got nowhere with support. I ended up having to go back to an old router just to have ethernet functionality. Best of luck.
- TheobuckSep 06, 2021ApprenticeThe tier 2 said that there was no way to go back to the previous version. I said well people on the Netgear community found a way. LOL
