Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
RjDes
Aug 10, 2021Initiate
Just saw this post, so my Orbi had been working just fine for last year or so. Ever since this update my wifi keeps dropping and its an absolute nightmare. I cannot revertback to the old firmware as its V3 on netgear website. I've posted my issues on anohter thread.
Stephonline
Sep 08, 2021Guide
I'm having similar problems. Initially blaimed it on comcast but nope, it'as the netgear
- FURRYe38Sep 08, 2021Guru - Experienced User
What problems are you having?
Have you contacted NG support yet?
Some speed issues are known to NG and are effected by only the built in speed test app on the RBR and the Orbi app. Using external speed tests apps are reported to show to spec speeds.
7 series users are encouraged to contact NG support and ask for the beta that seems to be being offered up.
- StephonlineSep 09, 2021Guide
Did not contact support since they want $$$ just to take a call.
I'm measuring speed with the Ookla speed test app on iphone and on direct connected laptop to router.
I'm having to reboot the router nightly; devices using the satellite to connect - both wired and wirelessly - are seeding 20 / 30 meg downstream as opposed to the 650mb that the router is reporting or that the direct connected laptop shows (approx 550 mb)
- michsuSep 08, 2021ApprenticeI put my 753 in AP mode and it still maxed out at 600. The disconnects have stopped though, but it seems the throughput is slower. AX is enabled. It must be the firmware of the 750 model.
It IS FW and NG is aware.
