Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
Stephonline
Sep 08, 2021Guide
I'm having similar problems. Initially blaimed it on comcast but nope, it'as the netgear
Sep 08, 2021Guru
What problems are you having?
Have you contacted NG support yet?
Some speed issues are known to NG and are effected by only the built in speed test app on the RBR and the Orbi app. Using external speed tests apps are reported to show to spec speeds.
7 series users are encouraged to contact NG support and ask for the beta that seems to be being offered up.
- StephonlineSep 09, 2021Guide
Did not contact support since they want $$$ just to take a call.
I'm measuring speed with the Ookla speed test app on iphone and on direct connected laptop to router.
I'm having to reboot the router nightly; devices using the satellite to connect - both wired and wirelessly - are seeding 20 / 30 meg downstream as opposed to the 650mb that the router is reporting or that the direct connected laptop shows (approx 550 mb)
