Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
SpeedPro_03
Sep 11, 2021Tutor
Will that FW also work with the RBK853?
Were can I get the FW v.4.6.3.16? I'm having many problems with v.4.6.3.9... All my 4 Satellites flashing colors all day long, disconnects from each other... slow speeds... I can't contact SUPPORT because they only give you 3 months free tech support and I don't wanna pay for something they screwed up with their last FW update...
Any help is welcome.
Thanks!
Theobuck
Sep 11, 2021Apprentice
I suggest contacting Netgear support. Or the moderators here may be to help others. I am not sure about sharing here. (sorry that sounds selfish) I would be suspicious if someone here shared a file that could be malicious.
- intergeek14Sep 11, 2021StarCan confirm we have been asked to not share the firmware link. Please reach out to the mods listed in this thread.
I’ve had it installed for 3 days now and it’s been back to the stability and dependability that I loved about this set up.- SpeedPro_03Sep 11, 2021Tutor
Ok, who do I have to email to get the FW link? Or how can I send a message to some Netgear technician and ask for it?
Thanks
- FURRYe38Sep 11, 2021Guru - Experienced User
Check your PMs.
Thanks
- TheobuckSep 11, 2021ApprenticeQuestion: One of the troubleshooting steps NG support had me under Advanced>Internet>Domain Name Server (DNS) Adress change the setting from: default (get Automatic from ISP) to Primary (8.8.8.8) Secondary (4.2.2.2). Should I keep that setting? Or go back to default?
Try the configuration out for a bit. Then try reverting.
