Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
Sep 10, 2021Guru - Experienced User
What happens if you turn OFF either RBS and use just 1 RBS?
CTS values to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
What channels are you using on the RBR?
TedsNotHere wrote:
Hi FURRYe38 here are the answers to your questions.Modem: Motorola MB8611 (I own)
Internet Service provider: Comcast Cable (I get ~200MB download speed)
Home Sqr feet: 2800 sq ft two story
Router wired to Satallite1 (not connected via Lan switch) on opposite sides of house
Satallite2 is about 20-30 feet away from Satallite1 (on same side of house as Satallite1)
I've rebooted via software reboot and physical unplugging power to reboot all router and satallites (yes waiting more than a 1 minute)
TedsNotHere
Sep 11, 2021Aspirant
FURRYe38 wrote:What happens if you turn OFF either RBS and use just 1 RBS?
FURRYe38 Here is what worked for me and steps:
- I unplugged Modem, Router & both Satallites
- Removed the wired backhaul (I think NG has a bug with wired backhaul)
- powered up modem waited from full startup
- then powered up Router waited until I can see router as connected in Orbi app
- Powered up 1 Satallite and again waited for it to full connected and be online
- Powered up 2 Satallite and again waited for it to full connected and be online
Once I completed these steps all the devices were able to connect and things seem to be back to normal. I should be able to use a wired backhaul but in with this current FW it's buggy and I believe it was what was causing the issues for me at least.
