Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
Jlhardwick
Sep 12, 2021Star
After getting the beta firmware and installing per instructions, I can report that it did not do anything to correct my device connectivity problems.
I will be downgrading to V3 until Netgear can fix this major blunder.
- jamacphotoSep 12, 2021ApprenticeSame here. Saturday , after installing the beta firmware is RBS and then RBB was fine till right now and has same issue of suddenly dropping some devices and not reconnecting till dona reboot. For now at least the beta seems to be not as bad and improved speeds. Lol
The fun continues- lngtme-orbi-usrSep 12, 2021Tutor
The fun continues indeed.
I had the RBK50 which worked perfectly for 3 years. Then I upgraded to RBK753 which worked nicely for 1 year - until v.4.6.3.7 that is!
To have a perfectly working system break for months (and still broken) due to a forced update is a particularly bitter pill to swallow. I'm sorry Netgear..it may be time to say goodbye..forever...
- CovertOp007Sep 12, 2021Aspirant
Is this thing on?! Testing. netgear, hello!?
Anyone having any luck getting the beta? Netgear admins should just be sending it out to people on here. This is absurd. Thank goodness for Costco's amazing return policy. Going to take it back. Costco should just drop the brand. Maybe try out the Linksys Wi-Fi 6 mesh system.
- FURRYe38Sep 13, 2021Guru - Experienced User
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
The fun continues
- JlhardwickSep 13, 2021Star
FURRYe38 wrote:Has a factory reset and setup from scratch been performed since last FW update?
Jlhardwick wrote:After getting the beta firmware and installing per instructions, I can report that it did not do anything to correct my device connectivity problems.
Yes, factory reset was performed. I can see not difference in the behavior with the beta firmware. I'll be downgrading back to v3 later today. If Netgear can't get it together soon I'll have an Orbi system to sell soon and move on to a company that supports it's customers.
Something to contact NG about and let them know what your seen then.
