Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
Sep 13, 2021Guru
Something to contact NG about and let them know what your seen then.
Jlhardwick wrote:
FURRYe38 wrote:
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Jlhardwick wrote:
After getting the beta firmware and installing per instructions, I can report that it did not do anything to correct my device connectivity problems.
I will be downgrading to V3 until Netgear can fix this major blunder.
Yes, factory reset was performed. I can see not difference in the behavior with the beta firmware. I'll be downgrading back to v3 later today. If Netgear can't get it together soon I'll have an Orbi system to sell soon and move on to a company that supports it's customers.
Akoi
Sep 14, 2021Tutor
Can someone send me the beta firmware for this please? even my setup when in AP mode is running like crap and the wifi is dropping internet constantly.
