Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
Mastra11
Sep 15, 2021Apprentice
Hello, this morning I found myself automatically updated router and the two satellites to version 4.6.3.16_2.0.51 Why is there not on the Netgear site ?? Is a beta version automatically installed ?? Thanks for the replies! ORBI RBK753
Sep 15, 2021Guru - Experienced User
Sometimes NG pushes FW out to systems before they put it up on there download site.
A beta WAS available to those who asked for it.
This is NOT a beta if auto updated.
Are you having problems with v16 after it was installed? Be sure to do a full power OFF of the system for 2 minutes then back ON.
- Mastra11Sep 15, 2021ApprenticeHello and thanks for the answer, now I have not yet restarted router and satellites, tomorrow if I can I try to restart router and satellites one at a time. But can you tell me what better this firmware than on the site there is? Thank you
- FURRYe38Sep 15, 2021Guru - Experienced User
Be sure to power them OFF fully for 2 minutes then back ON.
