Christian_R
Jul 16, 2021NETGEAR Employee Retired
RBK750 Series - Firmware Update v4.6.3.7
Hello Orbi AX Community,
We are excited to announce that we have started to roll out new firmware which enables NETGEAR Smart Parental Controls on RBK750 Systems. Customers with RBK750 series ...
Oct 09, 2021Guru - Experienced User
IF you unblock, you can get the update automatically. If you don't block and still manually update using the FW files. IF your blocking by using a upstream router.
Donsuper wrote:
Will I need to unblock those update site if I want to update the firmware one day? Or it will undo all the blocking in the update process? Thank you so much.
gthi
Oct 10, 2021Guide
This is what happens when you ping rhe router during wifi drop outs.
Firmware Version
V4.6.3.16_2.0.51
Time out and respons at the same time...
This is definitely a routing problem and has nothing to do with coverage.
I will return the whole 1800 euro system in te next couple of days dor a refund.
Good bye Netgear
Last login: Fri Oct 8 15:57:16 on console
ping 10.0.0.1
PING 10.0.0.1 (10.0.0.1): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
64 bytes from 10.0.0.1: icmp_seq=1 ttl=64 time=2390.607 ms
64 bytes from 10.0.0.1: icmp_seq=2 ttl=64 time=1882.943 ms
64 bytes from 10.0.0.1: icmp_seq=3 ttl=64 time=911.565 ms
64 bytes from 10.0.0.1: icmp_seq=4 ttl=64 time=247.726 ms
64 bytes from 10.0.0.1: icmp_seq=5 ttl=64 time=164.955 ms
Request timeout for icmp_seq 8
Request timeout for icmp_seq 9
64 bytes from 10.0.0.1: icmp_seq=6 ttl=64 time=4442.170 ms
64 bytes from 10.0.0.1: icmp_seq=7 ttl=64 time=3592.775 ms
64 bytes from 10.0.0.1: icmp_seq=8 ttl=64 time=2659.576 ms
64 bytes from 10.0.0.1: icmp_seq=9 ttl=64 time=1758.673 ms
64 bytes from 10.0.0.1: icmp_seq=11 ttl=64 time=446.292 ms
64 bytes from 10.0.0.1: icmp_seq=13 ttl=64 time=189.283 ms
64 bytes from 10.0.0.1: icmp_seq=14 ttl=64 time=206.045 ms
64 bytes from 10.0.0.1: icmp_seq=15 ttl=64 time=586.657 ms
64 bytes from 10.0.0.1: icmp_seq=17 ttl=64 time=879.643 ms
64 bytes from 10.0.0.1: icmp_seq=18 ttl=64 time=1997.987 ms
Request timeout for icmp_seq 20
Request timeout for icmp_seq 21
64 bytes from 10.0.0.1: icmp_seq=19 ttl=64 time=3749.005 ms
64 bytes from 10.0.0.1: icmp_seq=20 ttl=64 time=2903.914 ms
64 bytes from 10.0.0.1: icmp_seq=21 ttl=64 time=2062.794 ms
64 bytes from 10.0.0.1: icmp_seq=22 ttl=64 time=1072.782 ms
64 bytes from 10.0.0.1: icmp_seq=24 ttl=64 time=353.735 ms
64 bytes from 10.0.0.1: icmp_seq=25 ttl=64 time=256.697 ms
64 bytes from 10.0.0.1: icmp_seq=28 ttl=64 time=119.776 ms
Request timeout for icmp_seq 29
64 bytes from 10.0.0.1: icmp_seq=30 ttl=64 time=284.688 ms
Request timeout for icmp_seq 31
Request timeout for icmp_seq 32
Request timeout for icmp_seq 33
Request timeout for icmp_seq 34
Request timeout for icmp_seq 35
64 bytes from 10.0.0.1: icmp_seq=33 ttl=64 time=3801.090 ms
64 bytes from 10.0.0.1: icmp_seq=34 ttl=64 time=2798.878 ms
64 bytes from 10.0.0.1: icmp_seq=35 ttl=64 time=1981.872 ms
64 bytes from 10.0.0.1: icmp_seq=36 ttl=64 time=994.666 ms
Request timeout for icmp_seq 40
Request timeout for icmp_seq 41
Request timeout for icmp_seq 42
Request timeout for icmp_seq 43
64 bytes from 10.0.0.1: icmp_seq=41 ttl=64 time=3597.974 ms
64 bytes from 10.0.0.1: icmp_seq=42 ttl=64 time=2926.867 ms
64 bytes from 10.0.0.1: icmp_seq=43 ttl=64 time=1972.007 ms
Request timeout for icmp_seq 47
Request timeout for icmp_seq 48
64 bytes from 10.0.0.1: icmp_seq=49 ttl=64 time=70.251 ms
Request timeout for icmp_seq 50
64 bytes from 10.0.0.1: icmp_seq=50 ttl=64 time=1234.359 ms
64 bytes from 10.0.0.1: icmp_seq=52 ttl=64 time=343.502 ms
64 bytes from 10.0.0.1: icmp_seq=53 ttl=64 time=5.607 ms
64 bytes from 10.0.0.1: icmp_seq=54 ttl=64 time=250.506 ms
64 bytes from 10.0.0.1: icmp_seq=55 ttl=64 time=10.574 ms
64 bytes from 10.0.0.1: icmp_seq=56 ttl=64 time=46.056 ms
64 bytes from 10.0.0.1: icmp_seq=57 ttl=64 time=36.372 ms
64 bytes from 10.0.0.1: icmp_seq=58 ttl=64 time=77.407 ms
64 bytes from 10.0.0.1: icmp_seq=59 ttl=64 time=106.047 ms
- FURRYe38Oct 10, 2021Guru - Experienced User
Please visit and post about this in the 8 series v16 forum thread:
This thread is regarding the RBK750 Series - Firmware Update v4.6.3.7 which is now superceded by v14 for the 7 series Orbi.
Thank you.
Firmware Version
V4.6.3.16_2.0.51Time out and respons at the same time...
Good bye Netgear
