Bnichols907
Feb 12, 2022Aspirant
RBK750 wired backhaul from a wifi router to the RBK750 satellite
I have a remote building that I would like to get wifi in but I don't have another RBK750 satellite to put out there. Can I use my older wifi router and connect it with cat 6 to one of my RBK750 satel...
Feb 13, 2022Guru - Experienced User
You should be able to do that fine. I've connected extenders/access points to my satellites before.
Bnichols907
Feb 13, 2022Aspirant
Any settings that I have to change?
- michaelkenwardFeb 14, 2022Guru - Experienced User
You don't say what the spare router is, but generally to do what you describe, wired into another router, you should put the spare into Wireless Access Point (AP) mode.
