mnichollsuk917
Aug 12, 2021Aspirant
RBK752 - Awesome but disconnects on facetime a lot
Hey all Firstly, i love my RBK752! The router & Satellite have transformed the WIFI in my house but there is one odd issue My iPhone doesn’t like it, it seems to be ok when my iPhone (11 pro m...
mnichollsuk917
Aug 15, 2021Aspirant
Hey,
Thank you for the reply.
My home is 1500 square feet, the satellite is around 30feet away from the router going through 4 plasterboard walls. The link status says "GOOD" but every few days the light on the satellite goes solid blue and i have to reboot to make it turn off
2.4 is using AUTO
5 is using 36
I will now change to 2.4 - 1 and 5- 48 and provide feedback.
There are lots of other wifi routers in the vicinity
WMM is already enabled
I have disabled 20/40Mhz Coexistence
i can see the CTS threshold but cant seem to amend it?
when i changed 5ghz to 40 i get a message saying my service rate will drop to 20ghz which corresponds to a 286.6 mbps performance?
Set Short preamble instead of Long preamble modes - where is this setting ?
thanks for your help i appreciate it
mnichollsuk917
udpated on above, i have now changed both 5 and 2.4 to short & CTS on both to 2347
- FURRYe38Aug 16, 2021Guru - Experienced User
Let us know how it goes...
- mnichollsuk917Dec 13, 2021Aspirant
My iphone is disconnecting more thasn ever at the monment, any ideas please?
- FURRYe38Dec 13, 2021Guru - Experienced User
What happens when you disable AX mode on 2.4Ghz?
