mnichollsuk917
Aug 12, 2021Aspirant
RBK752 - Awesome but disconnects on facetime a lot
Hey all Firstly, i love my RBK752! The router & Satellite have transformed the WIFI in my house but there is one odd issue My iPhone doesn’t like it, it seems to be ok when my iPhone (11 pro m...
Aug 16, 2021Guru - Experienced User
Let us know how it goes...
mnichollsuk917
Dec 13, 2021Aspirant
My iphone is disconnecting more thasn ever at the monment, any ideas please?
- FURRYe38Dec 13, 2021Guru - Experienced User
What happens when you disable AX mode on 2.4Ghz?
- mnichollsuk917Dec 13, 2021AspirantIs the below ok - it’s the message I get
Per Wi-Fi Alliance guidelines for 40 Mhz and 20 Mhz coexistence, even if you select "Up to 573.5Mbps" mode, your product's service rate might drop to 20 Mhz. This typically corresponds to286.8 Mbps performance- FURRYe38Dec 13, 2021Guru - Experienced User
Yes.
You can set 40Mhz only as well under Advanced Tab/Advanced Settings/Wireless Settings. Just uncheck the check box next to 20/40Mhz.
