mnichollsuk917
Aug 12, 2021Aspirant
RBK752 - Awesome but disconnects on facetime a lot
Hey all Firstly, i love my RBK752! The router & Satellite have transformed the WIFI in my house but there is one odd issue My iPhone doesn’t like it, it seems to be ok when my iPhone (11 pro m...
mnichollsuk917
Dec 30, 2021Aspirant
I took a chance, all is ok, system has been reset back to factory defaults and has the latest firmware. I’ll make some FaceTime calls and report back my findings
mnichollsuk917
Ok so I’ve already had a dropped WiFi FaceTime call hours after the reset - what is the first step?
- FURRYe38Dec 30, 2021Guru - Experienced User
Try disabling AX mode on the RBR and set CTS to 2347.
I'd test Facetime device with with the RBS turned off to see if the problem continues...
- mnichollsuk917Dec 30, 2021AspirantTo confirm, RBR is the main router and RBS is is the satellite?
- mnichollsuk917Dec 30, 2021AspirantOk so I’ve disabled AX mode on the RBR and set CTS to 2347 this didn’t work
I’ve now reset both to factory defaults (with the latest firmware) this hasn’t worked
What is the next step please? - FURRYe38Dec 30, 2021Guru - Experienced User
And happens with the RBS turned OFF and the device connected to the RBR only?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and channel 40 on 5Ghz...
- FURRYe38Dec 31, 2021Guru - Experienced User
Something you might contact NG support about and see:
Actually I take that back, if you contact NG support, they may give you something:
What is the next step please? - mnichollsuk917Jan 04, 2022Aspirant
Latest:
- I have upgraded to the latest firmware and reset both units back to factory defaults
- All Wi-Fi devices work in the house perfectly over both the RBR and the RBS apart from my iPhone which disconnects on 99% of FaceTime calls immediately as i dial someone, WIFI reconnects the very second the FaceTime call ends
- I have tested unplugging the RBS and running a FaceTime call over the RBR only and the same happens
What are the next steps please? This is only a FaceTime / Apple issue - no other hardware or software is experiencing issues in the house
Thanks
Mark
- FURRYe38Jan 04, 2022Guru - Experienced User
Latest:
- I have upgraded to the latest firmware and reset both units back to factory defaults Did you upgrade to v4.6.6.11?
What are the next steps please? This is only a FaceTime / Apple issue - no other hardware or software is experiencing issues in the house. You might contact app and ask them for additional help and information regarding this and let them know this only happens on iPhones and Facetime.
Try setting CTS values to 2347 and enable WMM under Advanced Tab/Advanced Settings/Wireless Settings
I currently cannot change any settings on the Netgear router as it is going round and round in circles asking me to change the admin password - just something else wrong with it, does this fix itself?
I am in the UK and am using a EE Smart Hub
Your ISP modem may already have a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI recommend trying option #2 first.
I'd factory reset the RBR and setup from scratch on the RBR and walk thru the setup wizard using a wired PC and web browser. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com or 192.168.1.1 using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
- FodenJan 04, 2022Apprentice
Unit typically only asks to change the password when it's first setup or after a factory reset
- Have you reset the router?
- Is there an option to 'Skip', at the very bottom of the screen - if so try cclicking on that
- Double check the unit is not complaining tat your passwords either don;t match or are not complicated/complex enough
What settings were yuo looking to change anyways?
I posted a reply to this but it seems to have disappeared into the ether
The router usually only asks for admin password change on 1st setup or after a factory reset
Do you see an option to 'skip' at the bottom of the page, if so click that. If not double check that the router isnt complaining the the passwords don't match or are not complex enough
Took a look at the EE Smart Hub manual and it does not mention bridge mode. Lots of EE forum posts saying that you cannot put this unit into bridge mode. Cannot confirm 100% that this is correct, you'd have to follow that up.
Seems EE tech support don't know their arse from their elbow either. Smart hub looks like its ADSL/DSL so you'd need to replace it with a similar type unit and not a cable type modem
Hope that helps
While i try and sort the router login, even if this bridge mode was the issue - why would it only effect an iphone and facetime?
I can stream 4k on netflix, facetime on an ipad without any issues at all - how could the EE router be the cause of WIFI drop outs on an Orbi?
(keen to understand how this could be a thing)
thanks for your feedback so far
I have no idea to be honest, but the 'activities' you are using all work very differently and some are able to cope with dropouts without issue when others aren't.
Not a complete answer to the question but, network traffic (packets) often need to be resent as they don't checkout correctly at the receiving end. If you are browsing the web, streaming etc. (non real time events) you likely won't see this issue unless the retry rate gets very high. However, if you are using voice or video (real time events) you will see the issue even at low retry rates. Video drops, gets blocky or you can't hear or understand the voice.
On top of that each device can handle the data or process very differently with differing levels of success. The whole 'thing' is incredibly complex and something that we all now simply take for granted and over simplify it.
However, when this is your business you should'nt e in a position where an entire range of EXPENSIVE devices fail to function due to huma erro - Netgear
- CrimpOnJan 04, 2022Guru - Experienced User
This really sounds like an iPhone issue. Just a brief search turned up a number of hits regarding Facetime wifi vs. lte, such as:
The key seems to be "the instant Facetime is opened, it switches to LTE.. the instant the call drops, it switches back to WiFi"
That sounds like the iPhone, not the Orbi.
- mnichollsuk917Feb 03, 2022AspirantHey
I assume there is no news on this? I’m going to have to try another brand this is causing me such an issue now I’m running out of data on my phone each month as my iPhone is constantly flipping to 4G from the Wi-Fi
Thanks in advance - FURRYe38Feb 03, 2022Guru - Experienced User
Something to try:
Hey
Thanks in advance - mnichollsuk917Feb 03, 2022AspirantI cannot go through this again it’s a total waste of time - I have the latest firmware and it’s crap
Latest being whats on NG download site or what I linked you to?
And you never confirmed if your ISP modem/ONT has a built in router or not. - mnichollsuk917Feb 03, 2022AspirantMy router doesn’t have a built in modem
What is the advantage of the firmware you provided, does it fix iPhone disconnection issues? Is it new than the generic latest one provided by netgear as that’s what I’m using at the moment - FURRYe38Feb 03, 2022Guru - Experienced User
I was asking if the ISP modem has a built in router. Some modems/ONT do have a built in router. Some do not.
Current released version that was pushed, v14 cause lots of problems for lots of users, probably including you as well. We got a pre-released version from NG in hopes it would bring better stability and experiences for user who were not happy with prior FW versions. So far, seems to be having WAY better experiences for users. Something to try.
- mnichollsuk917Feb 03, 2022AspirantOk good to know, thank you I will try this tomorrow, does the master and the satellite both need the firmware updated?
Update the RBS first then the RBR lastly. Follow the upgrading information seen in the post.
- FURRYe38Feb 08, 2022Guru - Experienced User
OK were going to pick this back up here as we need to confirm what your ISP Modem (EE Smart Hub) Is doing and what it is.
Is your actual modem/router seen here?
https://www.eehomebroadband.com
We need the model # information of the modem of the sticker please.
So I just got off of a 15 minute facetime call to a Orbi 50 series user while my iPhone 12 Pro Max iOS 15.3 was connected to the RBR850 thats connected to a CAX80 in modem only mode. (Single NAT) Orbi 8 series on v5 FW. Using manual channes 11 and 48. 25% power on the RBR. I have two wifi systems i'm try to keep from creating too much noise. CTS at default of 64. SIP ALG disabled. AX enabled on both frequencies.
I kept checking the phone for signal change or anything odd. Not one event was seen nor did the phone change from wifi to cell during the call. No dropped call during the entire call.
Were thinking that your ISP Modem maybe playing a roll in what your seeing and we need to determine if the modem does have a built in router and if it's active while the RBR is online and also working in router mode. If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
