mnichollsuk917
Aug 12, 2021Aspirant
RBK752 - Awesome but disconnects on facetime a lot
Hey all Firstly, i love my RBK752! The router & Satellite have transformed the WIFI in my house but there is one odd issue My iPhone doesn’t like it, it seems to be ok when my iPhone (11 pro m...
mnichollsuk917
Feb 10, 2022Aspirant
Guys, thank you so much for all your efforts so far.
I have just borrowed my friends decos, set them up from scratch and…. The same issue is happening! So I can only assume there is nothing wrong with the netgear at all
Oddly it doesn’t seem to happen when connected directly to it EE router which suggests a conflict between the 2?
Foden
Feb 10, 2022Apprentice
Likely Double Nat as FURRYe38 suggested - I don't think the EE device can be put into bridge mode
Try this - (Presumption is that Windows is your O/S)
Open a Command Prompt and type the following, followed by the enter key
tracert google.ca
This will produce a list of devices between the router you are connected to and the address you entered, in our case google.ca – it can be any valid address you choose
The output of this command is below, without the headings – they were are added to aid explanation
Sometimes devices will not respond in time, and you will se an * rather than a time or you may just see Timed Out.
We are only interested in the first 2 or 3 entries in the list.
Entry #1
- Should be the internal IP address of the router you are connected to on your network. Typing this IP address into a browser will take you to the wed based administrative console of your router
- It’s IP should be within the Private Address Range specified at the start of this document
Entry #2
- Could be the internal IP address of a second router IF its IP address is within the Private Address Range specified at the start of this document
- Or
- It is the external IP address of your router, as found by using ipchicken.com and is NOT in the Private Address Range but the Public Address Range
Entry #3
- Don’t care if entry #2 is in the Public Address Range
- Or
You are Double NAT’d if entry #1 & #2 BOTH show a Private Address Range, regular single NAT will only have entry #1 as a Private Address Range
- mnichollsuk917Feb 10, 2022AspirantHey
Before I do the above, I’ve now had 2 drop outs when directly connected to the EE router!
It took around 30 FaceTime quick fire calls but it did happen - does this change things? - FodenFeb 10, 2022Apprentice
Yes, then you will know if you are Double NAT'd or not
- FURRYe38Feb 10, 2022Guru - Experienced User
Is the EE router also inlcude a built in modem or is this just a router only? If this is just a router, is there a modem or ONT infront of this EE Router?
Any luck with the tracert command?
On your EE Smart Hub, in the Hub Manager software you should be able to see this page
From the Home menu , go to Advanced Settings, then Firewall and then select Configuration. Look at the bottom of the page and yuo should see DMZ, if not please post a screenshot of what you do see
- Mikey94025Feb 11, 2022Hero
mnichollsuk917 wrote:
Hey
It took around 30 FaceTime quick fire calls but it did happen - does this change things?Yes, if when taking the Orbi out of the picture you still have dropouts then you should fix those before looking into the Orbi settings.
Anohter way to verify if you have Double NAT is to compare Your IP displayed by http://canyouseeme.org against http://orbilogin.com / Advanced tab / Internet Port / IP Address. They will be the same if your Orbi is exposed to the Internet. They will be different if you have Double NAT (you have another router exposed to the Internet and in front of the Orbi).
- mnichollsuk917Feb 11, 2022Aspirant
Here we go.... please tell me this tells us what we are looking for! :)
Thanks
Mark
1 3 ms 1 ms 1 ms 10.0.0.1
2 7 ms 1 ms 2 ms eehub.home [192.168.1.254]
3 15 ms 16 ms 14 ms 172.16.15.137
4 * * * Request timed out.
5 20 ms 19 ms 17 ms 213.121.98.136
6 23 ms 20 ms 22 ms 87.237.20.132
7 25 ms 18 ms 19 ms 74.125.52.216
8 58 ms 21 ms 20 ms 209.85.249.149
9 24 ms 18 ms 18 ms 142.251.54.27
10 25 ms 18 ms 18 ms lhr25s31-in-f3.1e100.net [142.250.179.227]
- FURRYe38Feb 11, 2022Guru - Experienced User
This is a double NAT condition:
1 3 ms 1 ms 1 ms 10.0.0.1 >Orbi or other wifi system.
2 7 ms 1 ms 2 ms eehub.home [192.168.1.254] >ISP Modem/Router
Were you able to find the DMZ on the ISP modems page as Foden mentioned? FT issue probably won't be resolved with Orbi or other wifi system until you can get into a single NAT condition at the modem, use DMZ or the modem can be bridged if possible.
Yes, i see the exact page he posted with DMZ on it - what should i do?
- FodenFeb 11, 2022Apprentice
You are Double NAT'd
10.0.0.1 is the IP address of your Orbi
192.168.1.254 is the IP address of your EE Smart Hub
Both IP's are within the Private Address Range
Follow FURRYe38's earlier post about DMZ
The reason i asked is when i turn DMZ on, it asks me to select a device - do i choose the IP of the Orbi? is that ll i do?
See msg #61 in this chain
Many thanks for that
10.0.0.1 is not showing in the drop down of all the IPs on the network
So it's only going to show you the 192.xxx.xxx.xxx IP range then, at least we have determined that you are double NAT'd
To clarify, you are able to get to the the web address of each router 10.0.0.1 and 192.168.1.254 from the same device, like a PC?
Also, 192.168.1.254 is not the default IP address for the EE Smart Hub, I believe it is 192.168.1.1
- mnichollsuk917Feb 11, 2022AspirantI’m out of the house now, back tomorrow - thank you all for your patience I’ll report back tomorrow
Not sure if this will work, but worth a shot
Is your EE Smart Hub setup as a DHCP server? If so, turn OFF DHCP and change the routers IP address to a static IP of 10.0.0.1
On the Orbi router turn ON DHCP, if its off, and set the router to have a static IP address of 10.0.0.2 and adjust the IP range it provides to start from at least 10.0.0.3
e.g.
10.0.0.1 EE Router Static IP DHCP Off
10.0.0.2 Orbi Static IP DHCP On
That puts all your devices on the same IP subnet – may need to tweak other settings but give this a shot
If it doesn’t work take screen shots of the settings you changed on the EE router and those on the Orbi, as well as the Internet Setup Page
- mnichollsuk917Feb 13, 2022AspirantI’m back home tomorrow, can’t wait to try this and see if we can get this resolved finally!
- FURRYe38Feb 13, 2022Guru - Experienced User
- mnichollsuk917Feb 14, 2022Aspirant
Hey,
yes i can get to both of those addresses from the same machine
Hey, if followed the guidance and changed the DMZ to on and selected
192.168.1.92 RBR, This is the IP address i found on the orbi page which is labeled as "internet port" on the advanced section - so ive put this in the DMZ section on the EE router and disabled both wifi radios
I have ran the below again and it looks the same to me?
Tracing route to google.co.uk [142.250.187.195]
over a maximum of 30 hops:1 6 ms 4 ms 4 ms 10.0.0.1
2 5 ms 4 ms 6 ms eehub.home [192.168.1.254]
3 18 ms 19 ms 19 ms 172.16.15.137
5 21 ms 21 ms 21 ms 213.121.98.136
6 21 ms 20 ms 42 ms 87.237.20.132
7 24 ms 23 ms 25 ms 74.125.52.216
8 20 ms 21 ms 22 ms 209.85.249.149
9 20 ms 21 ms 20 ms 142.251.54.35
10 21 ms 20 ms 21 ms lhr25s33-in-f3.1e100.net [142.250.187.195] - FURRYe38Feb 14, 2022Guru - Experienced User
It will look the same for a trace route. DMZ won't change how the trace route results. That will still see the router and ISP router/modem in the line.
ok, how do i know if the double NAT is fixed? I just tired facetime and it disconnected on the first attempt after making the change
on the EE page there is a setting to turn on "Enable SIP ALG" this is currently off
So still happening.
Seems that something with your ISP modem is problematic with putting a external router online with the ISP mode and even using DMZ, something is still failing for FT...
