Durpquad
Dec 29, 2020Star
RBK752 - Have to reboot at least twice a day
I just went from the RBK50 to the RBK752. Right out of the box the device notified of firmware update to: V3.2.16.22_1.4.9 So I didn't really spend any time on 3.2.16.6 Problem is that all t...
- Jan 02, 2021
Great. Please mark your thread as solved so theres will know. Enjoy.
Dec 29, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Be sure that CTS are changed to 2347. Save settings and reboot the router and satellite(s). under Advanced Tab/Advanced Settings/Wireless Settings
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
- DurpquadDec 29, 2020StarJust did a factory reset. Will let it go for a couple days and see if that helps.
- FURRYe38Dec 30, 2020Guru - Experienced User
Please give feedback on the other questions presented. Thank you.
- DurpquadJan 02, 2021StarMy setup has been rock solid since the factory reset. I did test with cts/rts at 2347 and it dropped my DL speed to 1MB. I backed off slowly and ended up back at 64. Dl speeds 180MB on the device I tested with. Also noticed at 2347 had issues with my ring equipment.
Everything is working great now.- FURRYe38Jan 02, 2021Guru - Experienced User
