Durpquad
Dec 29, 2020Star
RBK752 - Have to reboot at least twice a day
I just went from the RBK50 to the RBK752. Right out of the box the device notified of firmware update to: V3.2.16.22_1.4.9 So I didn't really spend any time on 3.2.16.6 Problem is that all t...
- Jan 02, 2021
Great. Please mark your thread as solved so theres will know. Enjoy.
Dec 29, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Be sure that CTS are changed to 2347. Save settings and reboot the router and satellite(s). under Advanced Tab/Advanced Settings/Wireless Settings
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
